Date/Time: Fri, 03 May 2024 14:07:27 +0000
Limit+Market order
View Count: 654
[2019-10-30 14:55:32] |
User2578 - Posts: 2 |
I trade option spreads. Is it possible to put this kind of order: if the spread price get to the target, broker puts limit order on the first leg and when the first leg is executed then the second leg goes by market?
[2019-10-30 23:15:13] |
No not at this time. The closest that would be available would be this study: Order Types: Spread Order Entry Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-31 17:12:52] |
Thank you for the answer! I've read but didn't understand - is Spread Order Entry Study an order type or just the way I can see a chart of my spread? |
[2019-10-31 20:28:48] |
The Spread Order Entry study does what it is documented to do.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-31 20:28:58
