Date/Time: Sun, 24 Nov 2024 23:04:42 +0000
How can i have two graph draw types on the same chart?
View Count: 1337
[2013-12-19 10:17:37] |
User48697 - Posts: 9 |
Hi, all is in the title, so, for example how can i have price represented in candlestick and moutain on the same chart, one up, the another down, as when you have the main price and an indicator in the lower level , talking about in another chart region? what i want to do is plot candlestick chart, and have its renko representation in the lower chart region to compare the two. Thanks! |
[2013-12-20 17:11:36] |
? Please ?
[2013-12-20 20:32:12] |
In general, what you want to do can be accomplished with the Overlay (Bar) study. You can set the Graph Draw Type with that study independently of the main price graph. But we do not know how you can have a non-Renko candlestick chart in one region and then the Renko representation another region. The two bar time frames will not match with each other. So it is not possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
