Date/Time: Fri, 03 May 2024 08:30:24 +0000
Out of bounds array error
View Count: 808
[2019-10-30 13:13:47] |
User907968 - Posts: 802 |
v2005 Upon loading chartbook, message log displays the following: "Chart #2 | Base Graph ID: 0 DateTime: Out of bounds array error at Index 0 | 2019-10-30 06:15:14.104" This message is repeated until the limit is reached: "Array message repeat count limit reached. | 2019-10-30 06:15:14.104" The message seems to be caused by "Study/Price Overlay" applied to Chart #2, which is linked to "High/Low for Time Period Extended" applied to Chart #4. This only seems to occur when the chartbook is first opened and data is downloaded. |
[2019-10-30 23:55:03] |
We will have a new release out later today which resolves this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-30 23:55:08
