Date/Time: Tue, 06 Oct 2026 05:45:01 +0000
Connection problem...
View Count: 1292
| [2019-10-29 23:51:37] |
| User629089 - Posts: 93 |
Hi, I'm trying to log on to SC's this evening and am unable. I'm getting this message, "Connection error message from service: Rithmic Trading / Logon error received from server / Date-Time: 2019-10-29 18:50:00 I'm thinking this may only be a temporary problem, but just in case there's some other problem I thought I'd better contact you. Everything worked perfect earlier today. Thanks... |
| [2019-10-29 23:58:30] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed with File >> Connect to Data Feed. After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-10-30 02:42:25] |
Here is the message log after about 30 seconds... Software version: 1941 64-bit | 2019-10-29 21:37:16.525 Usage end date: 2019-11-13 | 2019-10-29 21:37:16.525 Enabled for: Advanced Features. | 2019-10-29 21:37:16.525 Enabled for: Advanced Features 2. | 2019-10-29 21:37:16.525 Enabled for: Sierra Chart Historical Data Service. | 2019-10-29 21:37:16.525 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-10-29 21:37:16.525 Enabled for exchange: INDEXES_DATA_BARCHART | 2019-10-29 21:37:16.525 Enabled for exchange: CME (Trading Account Required) | 2019-10-29 21:37:16.525 Enabled for exchange: CBOT (Trading Account Required) | 2019-10-29 21:37:16.525 Enabled for exchange: COMEX (Trading Account Required) | 2019-10-29 21:37:16.525 Enabled for exchange: NYMEX (Trading Account Required) | 2019-10-29 21:37:16.525 Received 1 data feed usernames. | 2019-10-29 21:37:16.525 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-10-29 21:37:16.525 Current selected Data/Trading service: Rithmic Trading | 2019-10-29 21:37:16.525 Custom symbol settings values: enabled | 2019-10-29 21:37:16.525 Chart Update Interval: 500 | 2019-10-29 21:37:16.525 Intraday Data Storage Time Unit: 0 | 2019-10-29 21:37:16.525 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-10-29 21:37:16.525 2019-10-29 21:37:16 Local computer time | 2019-10-29 21:37:16.525 2019-10-30 02:37:16 Local computer time in UTC | 2019-10-29 21:37:16.525 2019-10-29 21:37:16 Local computer time in SC Time Zone | 2019-10-29 21:37:16.525 2019-10-30 02:22:25 Server time in UTC | 2019-10-29 21:37:16.525 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-10-29 21:37:16.525 Program path: E:\SierraChart\ | 2019-10-29 21:37:16.525 Data Files path: E:\SierraChart\Data\ | 2019-10-29 21:37:16.525 OS Version Number: 6.1 | 2019-10-29 21:37:16.525 Locale Setting: C | 2019-10-29 21:37:16.525 DLLs: Convergent.dll, Convergent_64.dll, Smaug_SC_Library.dll, Smaug_SC_Library_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-10-29 21:37:16.525 Rithmic Trading | Port for executable: 49713 | 2019-10-29 21:39:43.906 Listening socket (1196). Port 49713 | Closed. | 2019-10-29 21:39:43.906 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-10-29 21:39:43.906 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49713. Current folder: E:\SierraChart\Rim | 2019-10-29 21:39:43.906 Rithmic Trading | Bridge process is running. | 2019-10-29 21:39:45.916 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49713 | 2019-10-29 21:39:45.916 DTC Client socket (1) | Creating socket. | 2019-10-29 21:39:45.916 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-10-29 21:39:45.916 Rithmic Trading | Connected to server. | 2019-10-29 21:39:45.916 Rithmic Trading | Starting socket receive thread. | 2019-10-29 21:39:45.916 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-10-29 21:39:45.916 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-10-29 21:39:45.916 Rithmic Trading | Sending logon request message. | 2019-10-29 21:39:45.916 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-10-29 21:39:45.916 Rithmic Trading | Message from server: Logging is enabled. Log file: E:\SierraChart\Rim\Rithmic.log | 2019-10-29 21:39:45.916 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-10-29 21:39:45.916 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-10-29 21:39:46.196 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-10-29 21:39:46.206 Rithmic Trading | Received logon response. | 2019-10-29 21:39:46.206 Rithmic Trading | Server Name: DTC Bridge. | 2019-10-29 21:39:46.206 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-10-29 21:39:46.206 Rithmic Trading | Logon error received from server | 2019-10-29 21:39:46.206 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-10-29 21:39:46.206 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:39:46.206 Rithmic Trading | Disconnected. | 2019-10-29 21:39:46.216 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-10-29 21:39:46.216 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:39:46.216 Rithmic Trading | Port for executable: 49723 | 2019-10-29 21:39:48.226 Listening socket (940). Port 49723 | Closed. | 2019-10-29 21:39:48.226 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-10-29 21:39:48.226 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49723. Current folder: E:\SierraChart\Rim | 2019-10-29 21:39:48.226 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-10-29 21:39:48.946 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-10-29 21:39:48.946 DTC Client socket (1) | Closed. | 2019-10-29 21:39:48.946 Rithmic Trading | Bridge process is not running! | 2019-10-29 21:39:50.236 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49723 | 2019-10-29 21:39:50.236 DTC Client socket (1) | Creating socket. | 2019-10-29 21:39:50.236 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-10-29 21:39:50.236 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-10-29 21:39:51.246 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-10-29 21:39:51.246 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:39:51.246 DTC Client socket (1) | Closed. | 2019-10-29 21:39:51.246 Rithmic Trading | Disconnected. | 2019-10-29 21:39:51.256 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:39:51.256 Rithmic Trading | Port for executable: 49725 | 2019-10-29 21:39:53.276 Listening socket (1260). Port 49725 | Closed. | 2019-10-29 21:39:53.276 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-10-29 21:39:53.276 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49725. Current folder: E:\SierraChart\Rim | 2019-10-29 21:39:53.286 Rithmic Trading | Bridge process is running. | 2019-10-29 21:39:55.306 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49725 | 2019-10-29 21:39:55.306 DTC Client socket (1) | Creating socket. | 2019-10-29 21:39:55.306 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-10-29 21:39:55.306 Rithmic Trading | Connected to server. | 2019-10-29 21:39:55.306 Rithmic Trading | Starting socket receive thread. | 2019-10-29 21:39:55.306 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-10-29 21:39:55.306 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-10-29 21:39:55.306 Rithmic Trading | Sending logon request message. | 2019-10-29 21:39:55.306 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-10-29 21:39:55.306 Rithmic Trading | Message from server: Logging is enabled. Log file: E:\SierraChart\Rim\Rithmic.log | 2019-10-29 21:39:55.316 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-10-29 21:39:55.316 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-10-29 21:39:55.596 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-10-29 21:39:55.616 Rithmic Trading | Received logon response. | 2019-10-29 21:39:55.616 Rithmic Trading | Server Name: DTC Bridge. | 2019-10-29 21:39:55.616 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-10-29 21:39:55.616 Rithmic Trading | Logon error received from server | 2019-10-29 21:39:55.616 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-10-29 21:39:55.616 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:39:55.616 Rithmic Trading | Disconnected. | 2019-10-29 21:39:55.626 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-10-29 21:39:55.626 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:39:55.626 Rithmic Trading | Port for executable: 49735 | 2019-10-29 21:39:57.636 Listening socket (1064). Port 49735 | Closed. | 2019-10-29 21:39:57.636 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-10-29 21:39:57.636 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49735. Current folder: E:\SierraChart\Rim | 2019-10-29 21:39:57.636 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-10-29 21:39:58.316 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-10-29 21:39:58.316 DTC Client socket (1) | Closed. | 2019-10-29 21:39:58.316 Rithmic Trading | Bridge process is not running! | 2019-10-29 21:39:59.646 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49735 | 2019-10-29 21:39:59.646 DTC Client socket (1) | Creating socket. | 2019-10-29 21:39:59.646 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-10-29 21:39:59.646 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-10-29 21:40:00.646 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-10-29 21:40:00.646 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:40:00.646 DTC Client socket (1) | Closed. | 2019-10-29 21:40:00.646 Rithmic Trading | Disconnected. | 2019-10-29 21:40:00.666 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:40:00.666 Rithmic Trading | Port for executable: 49737 | 2019-10-29 21:40:02.676 Listening socket (696). Port 49737 | Closed. | 2019-10-29 21:40:02.676 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-10-29 21:40:02.676 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49737. Current folder: E:\SierraChart\Rim | 2019-10-29 21:40:02.676 Rithmic Trading | Bridge process is running. | 2019-10-29 21:40:04.686 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49737 | 2019-10-29 21:40:04.686 DTC Client socket (1) | Creating socket. | 2019-10-29 21:40:04.686 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-10-29 21:40:04.686 Rithmic Trading | Connected to server. | 2019-10-29 21:40:04.686 Rithmic Trading | Starting socket receive thread. | 2019-10-29 21:40:04.686 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-10-29 21:40:04.686 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-10-29 21:40:04.686 Rithmic Trading | Sending logon request message. | 2019-10-29 21:40:04.686 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-10-29 21:40:04.686 Rithmic Trading | Message from server: Logging is enabled. Log file: E:\SierraChart\Rim\Rithmic.log | 2019-10-29 21:40:04.686 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-10-29 21:40:04.686 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-10-29 21:40:04.986 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2019-10-29 21:40:04.996 Rithmic Trading | Received logon response. | 2019-10-29 21:40:04.996 Rithmic Trading | Server Name: DTC Bridge. | 2019-10-29 21:40:04.996 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-10-29 21:40:04.996 Rithmic Trading | Logon error received from server | 2019-10-29 21:40:04.996 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-10-29 21:40:04.996 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:40:04.996 Rithmic Trading | Disconnected. | 2019-10-29 21:40:05.016 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-10-29 21:40:05.016 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:40:05.016 Rithmic Trading | Port for executable: 49749 | 2019-10-29 21:40:07.046 Listening socket (1060). Port 49749 | Closed. | 2019-10-29 21:40:07.046 Rithmic Trading | Starting server: E:\SierraChart\Rim\DTCBridge.exe | 2019-10-29 21:40:07.046 Created process E:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:49749. Current folder: E:\SierraChart\Rim | 2019-10-29 21:40:07.056 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-10-29 21:40:07.716 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-10-29 21:40:07.716 DTC Client socket (1) | Closed. | 2019-10-29 21:40:07.716 Rithmic Trading | Bridge process is not running! | 2019-10-29 21:40:09.066 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49749 | 2019-10-29 21:40:09.066 DTC Client socket (1) | Creating socket. | 2019-10-29 21:40:09.066 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-10-29 21:40:09.066 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-10-29 21:40:10.066 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-10-29 21:40:10.066 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:40:10.066 DTC Client socket (1) | Closed. | 2019-10-29 21:40:10.066 Rithmic Trading | Disconnected. | 2019-10-29 21:40:10.086 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-10-29 21:40:10.086 File >> Disconnect selected. | 2019-10-29 21:40:10.646 Rithmic Trading | Disconnected. | 2019-10-29 21:40:10.646 |
| [2019-10-30 11:26:41] |
Hi, I'm wondering if there is any progress in figuring out what is going on? Everything is the same as last night. SC's loads everything but won't connect to the live data. I had something like this once with the Jigsaw Trading platform and the problem was that I had started to use FireFox as a browser and its virus protection was disrupting the connection to JS. I don't have FF anymore and the virus protection I use are MS Security Essentials and Malwarbytes free version haven't created any problems before. Looking at the Message Log it looks like there's something wrong with the Rithmic order routing or Rithmic data but the data runs perfectly well on the JS platform currently. I'm hoping we can get this resolved soon... Thanks |
| [2019-10-30 11:50:14] |
You are getting a permission denied error: Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | Refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
