Date/Time: Sun, 08 Sep 2024 00:05:58 +0000
[User Discussion] - Help coding simple ATR settings
View Count: 1319
[2019-10-29 22:31:16] |
User116733 - Posts: 4 |
Hello, I have no clue on coding and was wondering if someone can help with some simple coding. I am trying to have my ATR indicator show on screen with a different colors when the new bar is 1.25 * ATR (for 14 bar periods) So I think the generic formula would be : ATR > 1.25*ATR(14) Here's a picture of what I am sorta trying to achieve.. basically, ATR indicator at the bottom showing each ATR bar periods- black bars for normal ATR that doesn't exceed the ATR rule, green bars would be for buying volume that meets or exceeds the ATR*1.25 (for previous 14 period bars), and Red bars for selling volume that meets/exceed the ATR*.125 rule. When I added the ATR indicator on screen and then click on the property for ATR, it shows as ID11. I was told I need that info to write the coding.. Any help would be GREAT. Thank you |
Attachment Deleted. |
[2019-11-17 17:38:14] |
Ackin - Posts: 1865 |
Hi, you can download it as a finished study Study: "Average True Range - Colored" contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:47:30
