Date/Time: Sun, 19 May 2024 01:11:11 +0000
DAW crashes SC
View Count: 513
[2019-10-29 21:19:10] |
phaedonk - Posts: 352 |
I had detached a chart from the main window. Now every time I try to attach it again, SC crashes. Both 1991 and now 2005 versions.
[2019-10-29 23:01:40] |
We definitely do not believe this is a problem within Sierra Chart itself. Run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Do not use the OpenGL option if you are using that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
