Date/Time: Fri, 03 May 2024 11:44:21 +0000
Missing daily data, NQ futures CME, 2013-2016 SC Historical Data
View Count: 641
[2019-10-29 20:19:57] |
T44 - Posts: 363 |
Please see attached image, not fixed by a "Delete all data and download".
10007-2019-10-29-2016.png / V - Attached On 2019-10-29 20:19:48 UTC - Size: 39.05 KB - 251 views |
[2019-10-29 20:39:35] |
This is a continuous futures contract chart. Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-29 20:55:13] |
T44 - Posts: 363 |
I'm sorry, should have pointed out that I had done this. I've done it again step by step being careful about the symbol update and disconnecting / reconnecting as I have just changed from CQG to TT. Same issue unfortunately, what else can I try? |
[2019-10-29 20:56:08] |
T44 - Posts: 363 |
I should mention that this issue is occurring in a sub instance, I will delete and re-download in the master instance also.
[2019-10-29 20:58:54] |
T44 - Posts: 363 |
The data is correct in the master instance but incorrect in the sub instance. Not even sure how this is possible. Please see attached.
Private File |
[2019-10-29 21:06:08] |
We know why this is happening. This will be resolved in the next release.
[2019-10-31 11:38:16] |
T44 - Posts: 363 |
Thank you, this is now fixed.
Date Time Of Last Edit: 2019-10-31 12:59:10
