Date/Time: Mon, 03 Feb 2025 07:10:24 +0000
Message pop-up
View Count: 712
[2019-10-29 19:37:30] |
User750920 - Posts: 280 |
Hi, I am feeding SC with the GAIN feed (live). I do not want to trade through SC nor see the trades on my chart. I use GAIN's DOM. when I enter a trade 2 windows message pop up every time a trade executes. Is there a way to prevent this from happening. Thanks
[2019-11-01 17:17:33] |
Little Bump here... anything on this.
2019-11-01_Trade_pop_up_windows.png / V - Attached On 2019-11-01 17:16:24 UTC - Size: 249.29 KB - 342 views Attachment Deleted. |
[2019-11-02 10:52:12] |
No we cannot help with this. If you do not want to enter the trade account identifier in Sierra Chart, you are going to encounter those messages when using that service.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-02 10:52:24
[2019-11-04 15:10:12] |
So if I enter the trade account identifier then will my trades post on chart and will I be able to enter and exit trades via SC? Can you provide a link to enter the account identifier. Thanks for the help. |
[2019-11-04 20:31:20] |
No this is not correct. The chart would have to be in chart Trade Mode: Chart Trading and the Chart DOM Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
