Date/Time: Sun, 19 May 2024 00:03:04 +0000
Future Option
View Count: 530
[2019-10-29 14:47:50] |
Min Wu - Posts: 2 |
Hello, Can I trade Emini future (ES) OPTION on the platform? I use Gain Capital data feed plug in. Thanks. |
[2019-10-29 15:35:00] |
Yes you can. Sierra Chart does not support listing Gain Capital option symbols. You have to know what they are and then you can just manually enter them: File Menu: Find Symbol (File) With this service you can get listings of options and trade them easily: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
