Date/Time: Fri, 03 May 2024 10:27:33 +0000
Error creating async window. Windows error code 1158: The current process ...
View Count: 1066
[2019-10-29 14:12:21] |
User34124 - Posts: 271 |
Error creating async window. Windows error code 1158: The current process has used all of its system allowance of handles for Window Manager objects. | 2019-10-29 14:03:02.719 Unable to load data because there was an error creating the async callback window Hi this is what I get if I try to keep many chartbooks open at once. Is there any way round this? Ram is only at ~15% usage, I have plenty of system resources left |
[2019-10-29 19:31:31] |
You really need to use multiple Sierra Chart instances: Using DTC Server for Data and Trading in Another Sierra Chart Instance This is an operating system limitation. Not with Sierra Chart. The asynchronous callback window is only used temporarily in this case for data loading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-30 15:29:32] |
Ok thanks. How many charts does the O/S limit per per instance, as I have to plan ahead if I am going to utilise more instances. I think it looks like in the range off 1000-1500 per instance? |
[2019-10-30 19:39:05] |
We do not know. And there might be a registry setting for this.
