Date/Time: Sun, 19 May 2024 02:02:07 +0000
renew Sierra
View Count: 554
[2019-10-29 11:36:54] |
User864956 - Posts: 9 |
Hello My Sierra use will expire on 2019-10-31. If I renew it on 2019-10-31 or after this date, will all my chartbooks and data be saved? |
[2019-10-29 18:10:51] |
Yes.
[2019-10-29 19:26:49] |
Refer to: Software Download: Persistency of Chartbooks, Configuration and Other Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
