Date/Time: Fri, 03 May 2024 07:30:37 +0000
show same price on price-axis only once
View Count: 616
[2019-10-29 06:48:01] |
User735389 - Posts: 188 |
is it possible? something like the attached
Attachment Deleted. |
[2019-10-29 06:54:41] |
Show us an example of where you you see the same price more than once. Provide an image of that chart following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-29 07:04:28] |
The first image was an example to reflect what i wanted. Here's a raw image http://www.sierrachart.com/image.php?Image=1572332514461.png |
[2019-10-29 23:00:36] |
The problem is you changed the Price Display Format for the chart incorrectly. You need to increase it to .001. Refer to: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-30 08:02:28] |
that was done on purpose. i only want it to show in increments of .01 so i can quickly see what 1 pip is in the chart. I wasn't expecting this to be support but it'd be nice if it was.
[2019-10-30 09:10:58] |
User907968 - Posts: 802 |
You could set the scale increment to achieve the result you want. Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) |
scale increment.png / V - Attached On 2019-10-30 09:10:19 UTC - Size: 75.19 KB - 254 views |
[2019-10-30 10:32:18] |
You therefore need to adjust the Scale Increment setting: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-31 06:25:34] |
this is perfect, thanks
