Date/Time: Fri, 17 May 2024 19:45:27 +0000
Data
View Count: 459
[2019-10-29 04:52:17] |
User524539 - Posts: 14 |
The data streams (MESZ9 and NQZ9) have not been displayed since the beginning of this week. Why ? Thank you. Cedlam |
[2019-10-29 06:00:02] |
We see you are using Rithmic. Follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
