Date/Time: Tue, 21 May 2024 01:21:16 +0000
Numbers bars Search - feature request / suggestion
View Count: 786
[2019-10-28 20:43:20] |
EpictetusI - Posts: 9 |
Hello, I recently purchased your software for the year and I absolutely love it. I wanted to ask, do you have any plans to implement a feature that would allow to search for numbers bars which have specific characteristics, within the chart / dataset? For example, if I notice a pattern in 2 adjacent number bars, I can quickly search the rest of the day for any other instances of this pattern? If not, I think it would be a killer feature to add! Best, Gregory |
[2019-10-29 06:44:23] |
No, this is not planned. But it could be developed as a custom study. Refer to: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
