Date/Time: Mon, 03 Feb 2025 04:04:47 +0000
Symbols
View Count: 509
[2019-10-28 19:40:54] |
John Ara - Posts: 125 |
I 'm looking at sierra Global Settings >> Symbol Settings Do you know which one is Russell(RTY)? Please let me know if there is a matching table? Thank you. |
[2019-10-29 05:42:08] |
This depends upon the particular service being used. You are using CQG. It probably begins with F.US.RTY.
