Date/Time: Sat, 04 May 2024 15:24:14 +0000
Time Scale at bottom of chart missing
View Count: 620
[2019-10-28 16:12:42] |
John - SC Support - Posts: 31362 |
Now the Time Scale is too low. How do I adjust to come up a little more? Attache pic.
Attachment Deleted. Bottom of Chart2.PNG / V - Attached On 2019-10-28 16:12:21 UTC - Size: 7.47 KB - 225 views |
[2019-10-28 16:38:26] |
When that chart is active, select Window >> Maximize.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-28 16:38:44
[2019-10-30 02:34:12] |
DGee - Posts: 82 |
I have 3 other charts and they are okay but this one I have a problem seeing the scales below.
[2019-10-30 12:06:18] |
Did you select the command we mentioned in post #2 above?
