Date/Time: Mon, 20 May 2024 23:46:19 +0000
[Programming Help] - how to avoid choppy trend and small trend in Spread sheet automation
View Count: 577
[2019-10-28 15:05:50] |
User807128 - Posts: 18 |
i have implemented spread sheet by cross from below and cross from above function and moving averages and it works with replay chart . however , there are choppy trends and small trends that i want to avoid . are there any indicators ( e.g. angle of moving average , bollinger band squeeze or any other indicators ) that can help me to catch only the best trend and avoid the choppy market trend. i tried to use angle of moving average but it does not seem to work. i believe angle of let us say 50 day SMA or bollinger band will work if i choose few sample over time.but i do not know how to use that way. e.g. , if 50 day sma angle is good for 5 0r 10 smaple will do the trick. please let me know the following : 1. how to avoid choppy trend and small trend with spread sheet automation ? 2. how to catch the best trend using angle of sma or volume of buy or sale trades. thank you. |
[2019-10-28 15:07:40] |
i am using renko chart so it gives nice trend and it helps this way. but there are many small trends and choppy market trend. thank you. |
