Date/Time: Sun, 19 May 2024 01:41:45 +0000
Pourquoi mes oc sont mal pris exemple
View Count: 539
[2019-10-28 13:54:31] |
PONARD ANNE - Posts: 3 |
bonjour aujourdhui plein de souci de en coupant position ou sur mes oc ? comment se fait il ?
[2019-10-28 13:59:17] |
exemple sur le 27109 oc et pris a 27117 ?
[2019-10-29 06:58:36] |
This is not something we can tell from our side. Would be best to contact your broker about this. We cannot help with it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-29 07:12:50
