Date/Time: Mon, 20 May 2024 22:58:00 +0000
Cumulative Delta / Bitmex
View Count: 749
[2019-10-28 13:31:54] |
anpy - Posts: 35 |
The cumulative delta studies seem to behave strange with bitmex data... Cumulative Delta Bars study (default settings) > all candlestick bars are red Cumulative Delta Up/Down tick study (default settings) > red columns instead of candlestick bars. Changing draw type to "line on close" does not show anything at all Date Time Of Last Edit: 2019-10-28 13:35:22
[2019-10-28 18:08:04] |
This is what we see: http://www.sierrachart.com/image.php?Image=1572286063659.png Post an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-28 18:08:32
[2019-10-28 19:03:59] |
anpy - Posts: 35 |
Thanks! I did some testing and the problem turns out to be the "Round Price Bars to tick size" study. I applied it to the main price graph but somehow it seems to influence the cumulative delta studies. screenshot attached. |
Screenshot 2019-10-28 at 19.50.45.png / V - Attached On 2019-10-28 19:03:32 UTC - Size: 243.51 KB - 263 views Attachment Deleted. |
[2019-10-29 04:42:37] |
Therefore, then remove that study. Also check the color settings: Color Settings for Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
