Date/Time: Fri, 03 May 2024 08:49:58 +0000
Trade Service Log not opening v 2003
View Count: 504
[2019-10-27 21:18:18] |
T44 - Posts: 363 |
General Trade Settings | Open the Trade Service Log When a New Message is Added = checked Trade Service Log - clear log, close. Action: place a bid which would cause the max position for the symbol to be exceeded. Expected behaviour - Trade Service Log opens Actual behaviour - Trade Service Log does not open, but when opening it manually there are new messages (order will cause Symbol Setting Position Limit to be exceeded). Date Time Of Last Edit: 2019-10-27 21:18:41
[2019-10-31 07:30:03] |
Make sure this option is not enabled: General Settings Window: Never Automatically Open Message Log or Trade Service Log (Global Settings >> General Settings >> Log >> Log) But we will check in the case you mentioned if the log is not set to automatically open. It might not. The option you mention really applies to automated trading messages. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-31 07:30:46
[2019-10-31 10:20:32] |
T44 - Posts: 363 |
It was enabled, my mistake, sorry.
