Date/Time: Tue, 21 May 2024 05:11:44 +0000
Extend Poor High/Poor Low
View Count: 1049
[2019-10-27 08:12:08] |
nicktrader - Posts: 665 |
I am running ver.2003 but I cant find in the TPO study as described Time Price Opportunity (TPO) Profile Charts https://www.sierrachart.com/index.php?page=doc/Whats_New.php |
TPO Study.png / V - Attached On 2019-10-27 08:10:22 UTC - Size: 94.59 KB - 291 views |
[2019-10-27 08:26:48] |
Acro - Posts: 436 |
Neither can I. All I can see is that highs/lows can be include in peak/valleys and that you can extend line till intersection for peaks Not sure that aligns with the description of new input for extending poor highs/lows till intersection |
[2019-10-27 08:45:35] |
@Acro High/ Lows in Peak/ Valleys are different to poor high/ lows For my understanding there is offered a new input for poor high/ lows Additional it would be fine to mark a selling/ buying tail |
poor high.png / V - Attached On 2019-10-27 08:44:21 UTC - Size: 76.28 KB - 352 views |
[2019-10-27 09:24:42] |
This is an oversight that it was not actually released into the release build. We will put this out in about an hour.
[2019-10-27 16:15:01] |
Many Thanks. In connection with poor high/lows additional selling/ buying tails would be fine.
