Date/Time: Tue, 21 May 2024 08:42:51 +0000
Denali API/DTC?
View Count: 935
[2019-10-27 04:11:49] |
uM8137 - Posts: 180 |
If I find I need more speed, that going my-DTC-client -> SC -> Denali could be improved by going my-DTC-client -> Denali, is the Denali data feed accessible by DTC or other API? Thanks! |
[2019-10-27 09:39:47] |
Yes. Refer to: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
