Date/Time: Fri, 03 May 2024 14:43:54 +0000
Reverse Colors for value Labels does seem not work
View Count: 655
[2019-10-26 22:20:51] |
@sstfrederik - Posts: 403 |
The reverse colors for value labels in SG settings is not working well. It gets cancelled after activation.
[2019-10-29 17:01:03] |
Any news on this. It's not only my custom studies, but also regular other SC studies where the value label reverse colors do not work (ie simple MA study) On version 1997.
[2019-10-29 22:33:23] |
User365411 - Posts: 173 |
rel 2005 Same problem. Date Time Of Last Edit: 2019-10-29 22:33:55
[2019-10-30 13:14:02] |
We will be looking this over today.
[2019-10-31 08:21:19] |
rel 2006 solved TY |
