Date/Time: Fri, 03 May 2024 09:00:09 +0000
Support Package
View Count: 982
[2019-10-26 13:13:15] |
User324399 - Posts: 2 |
Hi, I would like to change the Sierra Chart package, right now I have package 3, I would like 5. Thanks
[2019-10-27 12:57:12] |
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-30 20:00:15] |
La Sierra Chart continua a non connettersi, ho cambiato il pacchetto ma non cambia niente
[2019-10-30 22:21:27] |
The problem is you have two Sierra Chart accounts and you are logging into the wrong one. You need to login with the Account Name: Moreno Boragine Here are instructions: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Let us know if you need further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-30 22:22:05
