Date/Time: Tue, 21 May 2024 13:54:33 +0000
sc.GetNumPriceLevelsForStudyProfile for TPO Chart VbP
View Count: 551
[2019-10-25 17:33:32] |
User353585 - Posts: 66 |
sc.GetNumPriceLevelsForStudyProfile sc.GetVolumeAtPriceDataForStudyProfile Hi, functions above don't seem to work for the VbP Study that is Based on TPO Chart. I'd like to use them for my custom study in TPO Chart. Can you please support it? Thanks. |
[2019-10-25 21:13:09] |
Yes that is true. Those functions will only work on the TPO Profile study in this particular case.
