Date/Time: Wed, 05 Nov 2025 05:51:58 +0000
Connectivity To Forex ECN: FXall, Hotspot, Currenex
View Count: 5344
| [2013-12-18 17:33:49] |
| Fraois - Posts: 12 |
I only found Sierra can connect to Currenex, but the FIX protocols are no big difference except Currenex supports stop orders while FXall, Hotspot do not. Can I trade FXall and Hotspot although I may not implement their data feed? FXall is one of the largest ECN now and they have exact the same FIX protocols with the popular EBS. Hotspot has 14.86% volume market share. Trading directly with Forex ECNs is what retail could get now, not a privilege only to institutions anymore. Files are downloaded from the internet. Looking forward to your answer Date Time Of Last Edit: 2013-12-18 17:38:44
Attachment Deleted. Attachment Deleted. Attachment Deleted. Attachment Deleted. Attachment Deleted. |
| [2013-12-18 23:04:15] |
We could add support for FX All Trading, but it is not likely we are going to do this without some reimbursement of the cost. So unless it is worth a few hundred dollars to you, we do not see it happening now.
| [2013-12-19 14:57:11] |
Is Hotspot trading already connected?
| [2013-12-19 17:07:56] |
No.
| [2013-12-19 19:11:44] |
Do you provide customized settings with hedging compatibility if creating this project? I'm willing to pay a few hundred dollars if that hedgin is allowed
| [2013-12-26 01:08:41] |
Hedging is an area we would not get involved with. There can be unexpected complications and we would rather avoid it. It probably is not a simple matter of settings which are specific to a Forex trading service because the trading functionality within Sierra Chart itself would have to be modified to support hedging. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-26 01:09:21
