Date/Time: Tue, 21 May 2024 20:50:48 +0000
Hiding Study Names AND Values from Region Data Line
View Count: 1047
[2019-10-25 14:09:29] |
User365411 - Posts: 178 |
With the option Hide Study Inputs On Charts (Global Settings >> General Settings >> General 2) only input values were hidden, study names remains visible. To hide names too I must check every study, it's very time consuming. Please can you add a keyboard shortcut or other fast way to hide/unhide all study input/values AND study names at the same time from all region data lines? TY |
[2019-10-25 15:39:51] |
No that is not something we would do. If anything that other global option would come out. It really is an older option.
[2019-10-25 16:05:09] |
Ouch .. too bad. It's very useful feature when you want to share a chart without all the settings. Ok ...If anything that other global option would come out. It really is an older option.
Sorry I don't understand this part, are you saying that you will remove the "Hide Study Inputs On Charts (Global Settings >> General Settings >> General 2)" option? I hope not ...TY |
