Date/Time: Tue, 21 May 2024 01:54:25 +0000
Delete key causes labels to appear on all drawn objects etc
View Count: 576
[2019-10-25 05:19:35] |
User234172 - Posts: 44 |
I swear, didn't change anything. Never seen this before. But I never used to hit the delete key either. Hitting the delete key causes numeric labels to print along all drawn object and some indicators (see count down timer and clock in image.) And also on trade connecting lines. see second image. The number values mean nothing to me. They are not labels or corresponding price levels. Right mouse click makes them go away. It is independent of chartbook and symbol. |
Annotation 2019-10-25 140917.png / V - Attached On 2019-10-25 05:18:41 UTC - Size: 30.53 KB - 330 views Annotation 2019-10-25 141853.png / V - Attached On 2019-10-25 05:19:24 UTC - Size: 17.28 KB - 342 views |
[2019-10-27 16:59:43] |
The reason for this is explained here: Chart Drawing Tools: Erasing Chart Drawings We have solved the problem in the latest prerelease 2004, with numbers showing up on trade drawings. Update following the instructions here: Software Download: Fast Update Also not really sure why you would see those large numbers instead of smaller numbers on the lines. See if you notice a difference after updating. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-27 17:00:56
