Date/Time: Tue, 21 May 2024 15:57:18 +0000
Transparent Candlesticks and Renko Bars
View Count: 665
[2019-10-25 03:51:57] |
User347150 - Posts: 29 |
Hello, Is there a way for the bars such as candlesticks or renko bars to become transparent so that the numbers in the bid x ask, and volume profiles in the volume by price indicator, can be seen through the candlestick and/or Renko bars ? Thank you very much for all of your help. Sincerly, Everett Date Time Of Last Edit: 2019-10-25 21:17:56
[2019-10-25 21:19:52] |
No but refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
