Date/Time: Tue, 21 May 2024 13:20:55 +0000
how to add display volume bar for bid/ask sizes
View Count: 719
[2019-10-25 03:33:51] |
User389151 - Posts: 37 |
how to add display volume bar for bid/ask sizes? see attached
Capture1.JPG / V - Attached On 2019-10-25 03:32:45 UTC - Size: 30.3 KB - 302 views |
[2019-10-25 21:07:28] |
Refer to: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
