Date/Time: Tue, 21 May 2024 10:03:29 +0000
Questions
View Count: 583
[2019-10-24 22:19:49] |
User226504 - Posts: 2 |
Some time in my trading desk I need to open Sierrachart (same data feed and simbols) in 2 PC Can I do this ? If not how I can do ? thanks you |
[2019-10-25 15:06:38] |
I got it. But is the server are in DEMO the client cant trade real account. How I can fix this ?? |
[2019-10-25 21:21:52] |
Yes you can do this, just install Sierra Chart again on the other system and logon. Refer to: Software Download To disable trade simulation mode, refer to: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-25 21:22:12
