Date/Time: Sat, 04 May 2024 21:42:45 +0000
The "Global Settings>> Graphic Settings Configuration" doesn't work
View Count: 1161
[2019-10-24 22:07:08] |
User230685 - Posts: 4 |
Hi, The "Save Days to Load, Intraday Bar Period, Graph Draw Types as Default " doesn't save. When I enabled it, after saving, the check box is empty. The "Global Settings>> Graphic Settings Configuration" doesn't work as well. So the "Graphic Settings" template doesn't work. A new chart doesn't open with my graphic settings, saved in the template. Could you, please, help with this problem? Thank you in advance. |
[2019-10-26 23:58:16] |
That first option, the state of it does not save. Tell us exactly what you have done: The "Global Settings>> Graphic Settings Configuration" doesn't work as well.
So the "Graphic Settings" template doesn't work. A new chart doesn't open with my graphic settings, saved in the template. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-26 23:58:25
[2019-10-27 01:30:10] |
Hi, 1). I have saved the "Graphics Settings" template for the chart in the "Graphics Settings - Global" menu. When I load this template to a new chart, the saved graphics values don't appear. The same result if I click the "Global Settings>> Graphic Settings Configuration>> saved template name" menu. 2). How the "Chart Settings>> Main Settings>> Save Days to Load, Intraday Bar Period, Graph Draw Types as Default" menu works? Thanks |
[2019-11-01 13:02:18] |
1. The documentation for that functionality is here: Graphics Settings: Saving and Loading Multiple Graphics Settings Configurations We will be reviewing the documentation and updating it as needed. It sounds like you may have a misunderstanding. 2. Refer to: Chart Settings: Save Days to Load, Intraday Bar Period, Graph Draw Type as Default (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-01 13:03:07
