Date/Time: Tue, 21 May 2024 09:23:34 +0000
pls help choosing data feed taking into cons. different dependencies
View Count: 935
[2019-10-24 18:38:19] |
User782857 - Posts: 2 |
Dears I was asked to move conversation from mail to here. Could you please run through 4 mails below and pls help. Thank you === 4 ============================================================================================================== Yes, it is complicated, but a lot of this is due to the rules that the exchanges themselves have put in place. At this point, you really need to post this to the Support Board, rather than through the email system. You will get a quicker response there, and it will be easier to track the progress. The link to the Support Board is here: https://nam11.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.sierrachart.com%2FSupportBoard.php&data=02%7C01%7C%7Cf39e78ce6933414ec3af08d758ac0783%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637075368190252142&sdata=BGSaIg52I3RRq%2BXVJvhkDWVDlt4pxJq7t2VsM7ywFZ8%3D&reserved=0 Thank You, Sierra Chart Support === 3 ============================================================================================================== Thank you for the response. Why it is so complicated..... I just wanted to trade futures..... : )) Ok. To be honest I do not understand these dependecies. I went through given links and pricing is like this and this .. but I must be careful of this and this ... and also take into into consideration that if this than this, and remebmer that if this than this, so overhelming... For Sierra Chart Exchange Data Feed what is: "For 100 Real-Time Symbols: 1st connection 35.00 USD/month. 2nd connection 20.00 USD/month. 3rd connection 20.00 USD/month. 4th connection 20.00 USD/month."? I do not follow how to resolve this: "Just be aware that if you setup the Order Routing with AMP, they are only setup to configure the Denali Exchange Data Feed with us, so you would need to setup the Sierra Chart Exchange Data Feed directly with us, since you want both Eurex and CME" How to collect all these puzzles in one place to know and compare costs, all is spreaded through different pages and dependencies. Pls advise. Thank you === 2 ============================================================================================================== Since you want to have both the Eurex and the CME Group, we recommend the Sierra Chart Exchange Data Feed. You will find the information for this here: https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.sierrachart.com%2Findex.php%3Fpage%3Ddoc%2FSierraChartRealTimeFuturesStockDataFeed.php&data=02%7C01%7C%7C1ac15e0ef12849fd498008d75898a40b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637075284927136267&sdata=N8eJ4ep9cBZAAZnaU3NzjRHJjr225EaerNIMvjRS4u8%3D&reserved=0 You also mention Server Side OCO, which is related to the Trading Provider and not the data feed. If you are interested, you can look into the Sierra Chart Order Routing Service, which is available through AMP. You will find the information here: https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.sierrachart.com%2Findex.php%3Fpage%3Ddoc%2FSierraChartOrderRoutingServiceWithData.php&data=02%7C01%7C%7C1ac15e0ef12849fd498008d75898a40b%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637075284927136267&sdata=efCkR9vctu0LYwUq9LqRKM4QNsU945JFa2HTJURA6Uc%3D&reserved=0 Just be aware that if you setup the Order Routing with AMP, they are only setup to configure the Denali Exchange Data Feed with us, so you would need to setup the Sierra Chart Exchange Data Feed directly with us, since you want both Eurex and CME. Thank You, Sierra Chart Support === 1 ============================================================================================================== Really thank you so much. I appreciate. DATA FEED TO CHOOSE pls help Data feed - I have acc. with AMP. I wanted to pick up CQG for Sierra but now I see you do not longer reccomend them. What would you recommend as data feed in that situation. My main focus is eurex - bund, eurostoxx, dax, than gbp and eur, than cl,es. Best if I have oco on the server side but not a must, i knew cqg did not not have it . === START ==== Date Time Of Last Edit: 2019-10-24 20:28:40
[2019-10-25 14:37:07] |
If you require EUREX we do recommend that you use CQG. We have a good alternative for CME group of exchanges, but not the best for EUREX. But we see you are interested in server-side bracket orders? So let us know if you want help going forward with the Sierra Chart order routing service, and the Sierra Chart Exchange Data Feed for EUREX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-25 20:53:18
[2019-10-25 14:47:15] |
Yes I am interested in server-side bracket orders as it is more save during the trade when loosing internet connection or smth is going wrong with hardware. But I can see there is a problem to achieve this with Eurex in general - do you know why is like that? And just to be aware could you pls specify why cqg for eurex, I mean what are advantages, I would like to be aware and to know. |
[2019-10-25 15:40:40] |
Well you can have server-side bracket orders when using the Sierra Chart Order routing service based on TT: Sierra Chart / Trading Technologies Futures Order Routing Service EUREX is supported with that service. But you will need to use the Sierra Chart Exchange Data Feed for the EUREX data. This data feed is 25 USD per month plus exchange fees and has to be directly paid for rather than through your AMP account. This is the only disadvantage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-25 15:42:20
