Date/Time: Tue, 21 May 2024 14:46:27 +0000
Cumulative Delta for different Participants
View Count: 915
[2019-10-24 18:19:50] |
User135370 - Posts: 160 |
Hi Can you guide me as to how I can begin to customise Cumulative Delta to filter Trade sizes So I wanna see the Delta for small contract orders say 5 or less medium say 50 and then large say over a 100 Is there a way to do this |
[2019-10-24 22:05:45] |
User136422 - Posts: 33 |
Yes, read here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VolumeFilterH
[2019-10-24 22:17:48] |
The best way to do this would be to create different charts with the filtering you want, then setup your Cumulative Delta for each chart. You will find the information for filtering trade volume here: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-24 22:18:16
