Date/Time: Sun, 24 Nov 2024 23:19:34 +0000
[User Discussion] - Create average daily range alert
View Count: 1574
[2013-12-18 09:49:21]
nioko54130 - Posts: 108
Hello dear support team,
i'm using the daily range statistic in my daily footprint chart, and i have implemented an average daily range statistic too on it. I would like to know how could i create an simple alert in order to know when an average daily range is reached.
Can i do it in a spreadsheet studie , and which formulas have i to use ?
Thank's!
[2013-12-19 05:09:55]
Is the Average Daily Range a moving average study based upon the Daily Range study Subgraph?
If you want to put an alert formula on the Numbers Bars Calculated Values study Daily Range Subgraph itself, you could do something like this:
= SG31 > 10
Here are the instructions:
http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#EnterAlertOnStudy
Date Time Of Last Edit: 2013-12-19 05:10:31
[2013-12-19 08:28:54]
Yes it is!
Thank's for the instructions,
In fact, i would like to use this moving average study base upon the daily range study to make an alert. For example, when the daily range reach the value of this moving average, the alert will be activated.
Do you see what i mean ?
Thank's!
[2013-12-19 08:39:25]
If my moving average is ID19.SG1, and my daily range is SG31 ; can i use this formulas :
= SG31 >= ID19.SG1 ?
Have i to set it (the alert) in the number bars calculated values, or in the moving average ?
Thank's
[2013-12-23 04:57:47]
This formula seems correct.
For the second question, we are not clear of all of the details. So we are not sure what study to put it on.
If you proceed each SG# with an ID number, it can go on any of the studies.
