Date/Time: Sun, 24 Nov 2024 13:06:21 +0000
[Programming Help] - Swing High Swing Low
View Count: 798
[2019-10-24 14:42:09] |
User837393 - Posts: 132 |
Hello, I'm currently using the swing high swing low indicator on a Flex Renko 1-1 chart. Is there any adjustement I have to do for the arrow to show when the swing happends ? The arrow is always showing only 4 bars later. Thank you for the support. Best regards, |
[2024-05-28 04:43:08] |
aswade3451 - Posts: 19 |
Hi, What is the 'Length' in the study set to? if it is too large the study will not show an alert until a larger swing is present- which could explain why it isn't showing up until a couple bars later. |
