Date/Time: Mon, 20 May 2024 23:37:34 +0000
Chart Header Font Size
View Count: 511
[2019-10-23 18:15:44] |
User622702 - Posts: 4 |
Hi Is there a way of changing the font size of the Chart Header ONLY and not the time and price axes as well? Thx Nat. |
[2019-10-23 21:13:52] |
No.
