Date/Time: Tue, 21 May 2024 15:33:53 +0000
Alert中Trigger Time如何修改?
View Count: 717
[2019-10-23 18:03:05] |
John - SC Support - Posts: 31771 |
报警中Trigger Time每次提醒的时间比较早,请问如何修改? From Google Translate:
Trigger Time in the alarm is earlier than each reminder. How can I modify it? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-23 22:27:49] |
Where in Sierra Chart are you referring to?
[2019-10-24 02:21:05] |
learners - Posts: 18 |
附件中红线圈出来的报警时间如何更改,默认的时间有时候会比较早,设置的报警一直在响。
微信截图_20191024101701.png / V - Attached On 2019-10-24 02:18:49 UTC - Size: 117.18 KB - 228 views |
[2019-10-25 00:33:13] |
The Trigger Date and Time cannot be modified. It shows the last trigger time.
