Date/Time: Mon, 03 Feb 2025 01:53:38 +0000
Transferring To New PC
View Count: 683
[2019-10-23 15:31:17] |
User940772 - Posts: 74 |
Hi, I just bought a new PC and looking to transfer Sierra and was wondering what the best way to proceed would be and what information is it you will need to transfer my account. Appreciate the help, JG |
[2019-10-23 16:09:47] |
This is something you just do from your side. Here is the documentation for this: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-23 17:06:09] |
Perfect! Just what I needed ... thanks.
