Date/Time: Tue, 21 May 2024 00:34:29 +0000
Summnation of price change
View Count: 668
[2019-10-23 14:52:32] |
Joshua Dawson - Posts: 5 |
Hello Guru, What would be the best method to add the percent change/price change from open on multiple charts? Example. Percent change for ES, NQ, YM, Russell 2000 es 1.0%, Nq -1.0% Ym 1.0% Russell 2000 1% = 3% percent change Also is there a an API from Sierra charts to feed into a python program? |
[2019-10-28 09:46:35] |
To see the percent change since open for multiple symbols, refer to: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=325&Name=Percent_Change_Since_Open#PercentChangeForDifferentSymbols Then you can use the Spreadsheet Formula study to add the Percentages together. Refer to the following: Spreadsheet Formula Also refer to: Using the Basic Arithmetic Studies Finally, you can display the result using the Text Display for Study study: Text Display For Study ---------------------------- Regarding Python, you can use that with the DTC protocol server: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-28 09:47:27
