Date/Time: Mon, 03 Feb 2025 12:46:27 +0000
From Build 1959 - New TPO Profile Study Inputs to display the TPO fields of data...
View Count: 905
[2019-10-23 12:08:14] |
User150852 - Posts: 38 |
Where can i define the following.... "New TPO Profile Study Inputs to display the TPO fields of data which are displayed in the Chart Values window, above or below TPO profiles." (from what's new) I am looking especially to show "TPOs Above/Below POC" Date Time Of Last Edit: 2019-10-24 08:38:51
[2019-10-24 23:35:03] |
You first need to update to the current version of Sierra Chart following these instructions: Software Download: Fast Update And then refer to: Time Price Opportunity (TPO) Profile Charts: Show Chart Values On Profile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-28 19:11:25] |
I would suggest adding another input to allow showing these only for the currently developing profile this is needed for more tactical decisions and the previous profiles values clutter the display |
[2019-10-29 03:54:06] |
Ok we will do this.
[2019-11-12 19:59:59] |
Also, currently you show the TPO data field 'TPOs Above/Below POC' as x/y (%x1/%y1). the text length is ok for chart values as width is no concern there but when showing on the chart the texts are too long and overlap between profiles. I think here it would make sense to break it into two options. or if I had to select one, i would go for the x/y and leave the percent out |
[2019-11-18 17:54:10] |
Ok we will do this.
[2019-11-19 09:05:28] |
Also, there is no way to control the numeric format for the Total Volume (e.g. big numbers convention - 5.5K) You have it in the 'volume by price' but not in the TPO |
