Date/Time: Fri, 03 May 2024 08:04:05 +0000
Unable to display estimated position in queue for limit orders
View Count: 534
[2019-10-23 04:58:23] |
vish100 - Posts: 111 |
Hi, SC documentation says "Estimated Position in Queue: In the case of a Limit order and Display Detailed Order Information and Display Estimated Position and Estimated Position in Queue Tracking settings are enabled, this displays the estimated position in the size/quantity on the bid side or ask side depending upon whether the order is a buy order or a sell order respectively. As this number approaches 0, the Limit Order becomes closer to being filled. This is preceded by the notation EP:" 1) I can't find the 'Display Detailed order information' anywhere 2) On enabling the other two i.e. 'Estimated Position' and 'Estimated position in queue' in Global Settings --> Chart Settings; the EP value is still not displayed on the chart order line. Can you help? thanks |
[2019-10-30 22:56:48] |
This is visible now. Solved
