Date/Time: Tue, 21 May 2024 06:05:57 +0000
Tick data charting
View Count: 500
[2019-10-22 18:04:25] |
U536222 - Posts: 40 |
hello I read through the tick by tick data config pages in the help but am unclear if I can chart bitmex with number of trades bars, where each candlestick or ohlc bar is X trades or ticks, using sierra charts. please advise. thanks |
[2019-10-22 18:34:27] |
Yes this is fully supported.
