Date/Time: Tue, 21 May 2024 13:02:40 +0000
Last daily candle: can only see the stem, not the body
View Count: 548
[2019-10-22 15:26:55] |
log585858 - Posts: 13 |
My data is from SC. Here is the AMZN chart that only shows the stem of the last daily candle. Only when I delete and reload the data, then the entire candle is painted. |
[2019-10-22 17:03:16] |
Not clear why that condition occurred but next time, open the Window >> Current Quote Window and position it over the chart and then post an image of the chart following these specific instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Are you noticing this now? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-22 17:04:27
[2019-10-22 18:19:21] |
Yes. Uploaded. http://www.sierrachart.com/image.php?Image=1571768318611.png
[2019-10-24 21:54:23] |
Hi, any idea why this happens?
[2019-10-24 22:04:22] |
How often are you noticing this? And what happens to the bar when you select Chart >> Reload and Recalculate? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
