Date/Time: Tue, 21 May 2024 02:58:04 +0000
Using the Sierrachart DOM
View Count: 805
[2019-10-22 14:07:05] |
User348929 - Posts: 16 |
Hi, I have an account with Infinity & Sierrachart. I would like to use the DOM from Sierrachart. How can i do it? For the moment, i only can trade on Sim with Sierrachart DOM. Message from Infinity: "You are able to trade through Infinity. As mentioned, if you would like to be able to trade through Sierra, you must contact them and request access to trade live. " Rgds, Corinne |
[2019-10-22 14:44:53] |
You just need to make sure that Trade Simulation Mode is disabled: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes And here are the instructions to use the Trading DOM: Chart Trading and the Chart DOM: Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-23 00:25:31] |
Hi, You ve sent me this mail... > > > Sierra Chart Engineering has posted to the thread: "Using the Sierrachart DOM". Click on the following link to view the response: > Using the Sierrachart DOM > > But you don t understand my problem. I know The Trade>Trade simulation Mode on. I used the Sierrachart DOM for 2 months when i was with Stage 5. But i ve quit Stage 5. For Infinity. And Infinity has his own DOM. And Sierrachart DOM is blocked. On Sim what ever i do. Sim When Trade Simulation On Sim when Trade Simulation Off. But I m used to Sierrachart DOM. I would like to trade again with Sierrachart DOM. Markus from Infinity told me to contact Sierrachart to unblock the DOM. Thanks to unblock Sierrachart DOM. RGds, Corinne |
[2019-10-23 05:10:25] |
There are definitely no restrictions on the Sierra Chart side relating to this so we have to call you to look at this. When is a good time to call?
