Date/Time: Sat, 26 Apr 2025 15:40:46 +0000
EUREX and ICE Exchange Support
View Count: 6791
[2014-01-01 20:03:07] |
crazybears - Posts: 314 |
Hi Sierra Chart Engineering Happy New Year Do you apply discount if someone buy 1 year of your complete data feed ? CME+EUREX+ICE :) |
[2014-01-01 20:18:36] |
No. We cannot possibly do that. You do not know how expensive exchange data is.
[2014-01-01 20:38:52] |
GPST10 - Posts: 139 |
Would add FSMI, FESB to the mentioned ones, that's it. Thanks |
[2014-01-01 20:41:35] |
Hi sorry if i have been impolite , i only wanted to know if was possible . if i choose the full pack of datafeed the total price is : 35+31.5+94.5 with L2 data ,right? How much history of ticks data can be downloaded for each market? The exchange fee will be reduced for the EUREX, once the market depth exchange fee component is separated out. Right now level 1 and level 2 data are combined together. We expect this will be done sometime in January.
assuming i choose ,when available only l1 data , can i feed my DOM with l2 data e.g provided by CTST4 ? I mean in the same chart .do you think this division between l1 and l2 data with the consequently reduction of price will be extended to CME and ICE also ? interesting only if can be used your datafeed and another datafeed for the DOM in the same char , otherwise i choose full subscription |
[2014-01-01 21:15:57] |
Understood, you were not being impolite. Yes, this is the correct pricing in USD: 35+31.5+94.5 For CME there is about 3 years of tick by tick data. For EUREX there should be about 1 year. But we would have to check on that. And there is more 1 minute history available. assuming i choose ,when available only l1 data , can i feed my DOM with l2 data e.g provided by CTST4 ? I mean in the same chart . With the CME there are no exchange fees at the time being, so there is not any separate pricing between level 1 data and market depth. We do not expect the ICE to have separate pricing for market depth data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-02 02:48:31] |
Could you please enable my account for using the EUREX datafeed, when it is available? We will provide instructions on how to do this. Would add FSMI, FESB to the mentioned ones, that's it. Swiss Midcap Index Symbol: SH Euro Stoxx Banks 600 Symbol: FA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-02 04:20:36] |
Unfortunately EUREX and ICE is going to be delayed about half a day. We need more development time. Thank you for your patience. It will be released sometime during January 2 before the end of the day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-03 04:28:30] |
At this point, EUREX and ICE exchange support with the Sierra Chart Real-time and Historical market data feed is now available. We are working on the documentation for this. This will be done before the EUREX open . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-03 06:56:27] |
EUREX and ICE is now available. Refer to this new thread for instructions: EUREX and ICE Support with Sierra Chart Data Feed Now Available! Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
