Date/Time: Tue, 21 May 2024 06:00:14 +0000
Save Study Setting
View Count: 2229
[2019-10-22 13:21:12] |
User551971 - Posts: 34 |
Hi, is it possible to save the settings of a study to use them in another chart ? Or to copy them to another chart without deleting an existing study ?
[2019-10-22 21:55:25] |
There are two different possible ways to do what you are asking for. Refer to the following: Chart Studies: Using Custom Default Study Settings and Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-23 09:41:59] |
Hi, these two ways are known to me but do not do what I want. Saving the values as default doesn't fulfill the purpose because I can't save different values. Always only one as default. The Study Collection is more like what I want, but when I load the Study Collection, all already created studies in the chart will be deleted. Also, I can't load several collections at the same time, or is that possible? |
[2019-10-23 11:51:53] |
all already created studies in the chart will be deleted. Also, I can't load several collections at the same time, or is that possible? There is an option to not remove existing studies on the chart when applying a Study Collection. Refer to:Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
