Date/Time: Tue, 21 May 2024 02:05:34 +0000
Data missing for APPLE
View Count: 481
[2019-10-22 09:27:47] |
User999647 - Posts: 38 |
Hi, It seems that there is a miss of APPLE (AAPL) stock's data between 6/Nov/2018 and 1/April/2019. The problem is still there after re-downloading data. Anyone could help? Thanks. |
[2019-10-22 11:27:00] |
This data is not missing on the Sierra Chart server. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-22 11:27:17
