Date/Time: Tue, 21 May 2024 02:17:25 +0000
How to duplicate Auto Trendline to make a Channel
View Count: 954
[2019-10-22 05:50:05] |
sourdubber - Posts: 52 |
I like the automatic trendline offered as indicator. But instead of 1 treandline, I owuld like to see a parallel line to forma a channel. I wonder if there's a easy tweak to a automatic trendline to do this?
[2019-10-22 23:44:39] |
Use the Arithmetic studies to create the second line then use the Study Subgraphs Reference to color in the channel. Refer to the following: Using the Basic Arithmetic Studies Study Subgraphs Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
