Date/Time: Sun, 24 Nov 2024 23:15:53 +0000
Live Data
View Count: 1208
[2013-12-17 20:49:10] |
User96371 - Posts: 2 |
I am not getting a live quote on my charts. When I pull up a chart it gives me a quote but does not change after I bring up the chart.
[2013-12-17 21:25:14] |
Please give us the symbol of the chart.
[2013-12-17 22:53:24] |
AMZN, NFLX, LNKD, etc...
[2013-12-17 23:25:47] |
You do not have the correct Service selected within Sierra Chart. You need to change the service through Global Settings >> Data/Trade Service Settings. Did your broker tell you what to use? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
